Home > Off Topic - Other Cars > My RRS 2005 TDV6 WON'T MOVE...!!!
Alfafox
France
Hi!
Last week i needed to stop on the road because no more power on my weels.
No lights flashing on the dashboard, no defaut and the engine is ok.
Only a big F on the left of the P, R,,N,D indicator on the dashboard.
When I restart and I put in D = no power on the wheels.
When I put in R = no power on the wheels
And when I come back on P an anormal sound (clac,clac,clac,clac,clac......) append under the car and the P position won't engage.
When I stop tbe engine and I can put on P and remove the key.
I restart the engine, I put on N and I change my transfert case on Low........ all the lights flash on the dasboard ( default suspension, default transmission, defaul electrix hand brake...etc), the light "LOW gear" flash in green on the dashboard and the button LOW/HIGHT flash orange and I cannot change nothing.
The engine is ok but on R or on D my RRS won't move (electric parking brake desengaged).....🤔🤔🤔🤔🤔
I don't know what appends......the Gearbox? The Transfert Case?
Thanks for your help!
Post #616564 16th Dec 2021 12:19am
Sorry sir but you need the sister forum for the RRS... Thumbs Up
Post #616565 16th Dec 2021 12:31am
Alfafox
France
What is the "sister forum"?
Post #616586 16th Dec 2021 9:54am
Alfafox
France
Can you give me the "https://www." address?
Thanks a lot.
Post #616588 16th Dec 2021 10:00am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Here you go
https://www.rrsport.co.uk/forum/ 2011 TDV8 Vogue SE
Post #616595 16th Dec 2021 10:16am
dingg1
This happened to me when one of the ds popped out after some maintenance had been done, could be a drive shaft issue, or prop shaft or fretting corrosion to gearbox splined shaft
Hth
Post #616597 16th Dec 2021 10:23am
Alfafox
France
Ok thanks both.....!!
Post #616635 16th Dec 2021 2:22pm
