Home > Maintenance & Mods (L405) > Batteries and Stop/Start |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 335 |
I thought it was the auxiliary battery thar was responsible for Stop/Start.
14th Dec 2021 11:32pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1098 |
My car has just had its 6th birthday, the stop start has not worked for a few years and I decided it was time for a bit of pro-active work so had both batteries replaced at the service. Stop start working again, so now I start the car and turn off the stop start straight away. letters not necessarily in the right order |
15th Dec 2021 6:23am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3753 |
It’s the small auxiliary battery behind the rear right boot panel that needs replacing - or it’s been disconnected 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
15th Dec 2021 6:35am |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
Thank you all.
15th Dec 2021 8:04am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7954 |
Entirely possible.
15th Dec 2021 8:22am |
nickt68 Member Since: 05 Nov 2010 Location: Herts Posts: 99 |
I’ve got a 2015 SDV8 and pretty sure mine hasn’t got stop/start |
15th Dec 2021 8:25am |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 873 |
Came in on MY16 models through 2015 (generally 65 plate onwards) will have a stop/start off button on centre tunnel if it’s fitted |
15th Dec 2021 8:45am |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
Both batteries on my 15 plate tested as good, but stop start worked once every now and again. Replaced both and it works all the time now Not sure if thats a good or bad thing... Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
15th Dec 2021 9:17am |
Mine was first registered 1.3.15 and I've not seen a stop / start button - will have to double check now.
15th Dec 2021 9:18am |
mlambton Member Since: 30 Sep 2021 Location: Devon Posts: 67 |
Stop/Start was a£460 option on MY2015 and not a standard fit on any model including the AB and SVAB 2015 Range Rover L405 SDV8 AB Corris grey
So all cars had the aux battery. But you only got stop / start - and the button for it - by paying the £460 extra? What do I put here then? |
15th Dec 2021 9:22am |
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 179 |
Yes, but think of all of the money you save when stuck in traffic. |
15th Dec 2021 9:38am |
Pretty sure it was standard on all MY16 models onwards, happy to be corrected. |
15th Dec 2021 9:45am |
The second battery is there because why not ?
15th Dec 2021 9:52am |
