Home > Maintenance & Mods (L322) > Fuel level reading disappeared.
Tattiepicker
United Kingdom 2011 Range Rover Vogue TDV8 Mariana Black
Over the weekend I had the back seats folded down and the boot fully loaded going to the skip. All of a sudden the fuel level gauge starts reading 0 and the range went to 3 dashes —-. Don’t know if I have nicked a wire for the level readings?? I checked the fuse in the centre fuse box and all ok with it. Anyone any ideas why it would suddenly go to 0?
Post #615744 10th Dec 2021 6:35pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
IIRC the sender / level connectors are under the back seat squabs which are easy enough to remove. Might be worth checking of you have loaded heavy out over tank. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #615843 11th Dec 2021 12:28pm
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
Mine did that once for no apparent reason - thought "someone's nicked my diesel" (was about 1/2 full) so I put my spare 10L in & went to refill, put around £50 in & on restarting the gauge went up to 3/4.
Maybe worth a top up ?
Post #615848 11th Dec 2021 12:38pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
classic problem on L322 & there's plenty of threads on here to explain how to fix it 2010 VSE [Roger]
Post #615907 11th Dec 2021 9:27pm
