Home > Maintenance & Mods (L405) > Seat refurb 4.4 heated/cooled seats .
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Anyone done it , heated part not working (base and back ) so to fix base seat will need stripping , cushioning getting tired and usual outside edge beginning to look shabby , just wondering what's involved and can you get new leather to match ?
Post #615846 11th Dec 2021 12:37pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Its highly likely the seat back unit has failed causing the entire seat to stop working.
(we sell repair kits)
You can remove the unit for the base under the seat.
To get to the seat back unit you need to remove the plastic section at the back of the seat.
Post #615892 11th Dec 2021 7:09pm
Graham4242
United Arab Emirates 2011 Range Rover Autobiography 5.0 SC V8 Alaska White
I’d be very interested in this repair kit. My seat back doesn’t blow air (drivers side). I started following the powerful video and lifted up the lower leather centre section however I have additional pieces. That mould around the side.
One question, to replace the broken air duct can it be done from the back of the seat? Current
2011 Autobiography, 2014 Vogue SE Supercharged
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #615903 11th Dec 2021 9:13pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
You will need to undo the 4 bolts that hold the seat down, Which makes it easier to remove the side covers, the seatback is pushed down after releasing the sides off the spline left/right.
That gets you to the heating-cooling unit.
it may not be a broken duct it could be the peiter unit that's gone, both of mine had gone with no broken ducts?
My advice is to replace the complete unit to save you from going back in again?
Post #615915 11th Dec 2021 10:09pm
Easy peasy to take the seat out of the car HOWEVER!!! Be careful NOT to scratch plastics or paintwork when lifting it out of the car... The drivers side seat is much easier to remove if you also remove the steering wheel... Thumbs Up
Post #615929 12th Dec 2021 12:59am
matthews
My cock up , stuck in it 405 section and should of stuck it in 322 !!!!!, hopefully answers are relevant especially the repair kit , heater still doesn't work when just the base is on so I recon both elements have gone .
Post #616251 14th Dec 2021 12:13am
If one peltier motor is compromised (even with an air leak) the whole seat will shut down... Thumbs Up
Post #616257 14th Dec 2021 12:27am
