Home > Maintenance & Mods (L322) > Iv'e started work on my Autobiography as they say. |
suburbanspaceman Member Since: 10 Aug 2021 Location: Burton On Trent Posts: 31 |
Please can anyone help with my previous questions?
7th Dec 2021 12:57pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3110 |
Have you cleared the codes to see what comes back yet? There's a chance that some of them will be historic so personally, I'd clear the codes, use it for a few days and see what comes back.
7th Dec 2021 1:20pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3776 |
DPF remaining volume…I don’t know why , but they all read 0.
7th Dec 2021 1:35pm |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 72 |
Not sure if this is any help bit I recently did some welding on my, then new to me, 2007 TDV8 FFRR. No dpf so I suspect yours is newer. I was unaware of any particular precautions or procedures so simply disconnected the battery completely, neg first, and welded away, with the 'earth' close to the weld site. I waited a short while before welding and didn't do the live terminal to earth trick (as i was unaware of it!) I was tig welding, which is arguably potentially more likely to create havoc with electronics by virtue of the hf (high frequency) arc starting. I did not have any problems whatsoever. I might have just been very lucky! I've got the rear end of the sills / front of rear wheel arches to do sometime soon so I hope my luck stays good! Your mileage my vary!
7th Dec 2021 2:29pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 |
As Baltic said re: the DPF, ignore completely unless you get frequent yellows.
7th Dec 2021 4:13pm |
Thank you all for your replies, I was beginning to think I’d contravened some forum etiquette 🙂
9th Dec 2021 1:44pm |
