Home > Technical (L405) > Low Coolant Warning - L405 5.0 Supercharged |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Oh yes there should be fluid in the reservoir up to the marking.
8th Dec 2021 5:23pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1388 |
Thats great, many thanks, should i top up with JLR coolant, I have some antifreeze/coolant I picked up from Shell garage would that be ok to use and not have any issues with any coolant left in it |
8th Dec 2021 5:59pm |
I wouldn’t mix unknown coolant. The Range Rover 5.0SC takes G30 iirc. But best to double check online with your reg number. It’s a red colour for me. |
8th Dec 2021 6:14pm |
I did wonder if that would be the case, thank you, what web site do i check with please? |
8th Dec 2021 6:16pm |
I can’t believe in saying it but you could use Halfords or Euro Car Parts
8th Dec 2021 6:19pm |
Brilliant, many thanks, I think a call to the dealer in the morning and get booked in and prepare myself for the bill |
8th Dec 2021 6:21pm |
Parts shouldn’t be expensive, but the labour of the investigation could be. I would definitely use an independent specialist for this, unless you’ve got a big warm garage as it isn’t really hard. I would elect to instruct them to just replace all the hoses if it’s supercharger off as the parts costs nothing compared to labour. And perhaps take the opportunity to refurbish the supercharger unless that was already done. It’s a little bit more now but saves a lot come a bit later. |
8th Dec 2021 6:34pm |
Good advice, thank you, will do |
8th Dec 2021 6:36pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1374 |
Ownerinfo.landrover.com gives the coolant spec as STJLR.651.5003, mix of 50% water and 50% that coolant. Dealers sell coolant and when I had a low coolant warning on my 2012 WM when in holiday in England I just called into the nearest dealer and bought some from there, rather than going to (say) Halfords and having to read small print specs for a small saving. Only Range Rovers since 1988 |
8th Dec 2021 6:43pm |
Thats great, I agree, I will take her straight to the dealer and I won't muck around with it.
8th Dec 2021 6:45pm |
It makes me wonder whether a dealer actually has the tools for this; inspection camera to confirm my suspicions. I just see dealers as people who replace things but don’t actually repair or fix if you know what I mean. |
8th Dec 2021 6:57pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3072 |
Earlier L405’s seem to be suffering from coolant leaks from the rear of the car these days from what I’ve been reading. The pipes going into the rear heating corrode I believe.
8th Dec 2021 10:06pm |
Thanks for all your help, I wont be putting anything in, i shall leave that for the dealer.
8th Dec 2021 10:17pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
DrF hi, From cold... if you open your bonnet and look at the side of your coolant reservoir you will note a minimum and maximum line... If you cannot see any coolant (should be an orangy pink colour) then grab an empty milk carton swill it out and put some plain clean water in it, then fill the reservoir to the minimum line. The added benefit of using a milk carton is you can be sure how much water you have needed to fill her back to the minimum/maximum line...
9th Dec 2021 12:10am |
