![]() | Home > Maintenance & Mods (L322) > Driver’s door card removal / working around the airbag |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
It covers a torx head screw that has to come out along with the others get the card off the mirror connections are behind door card but the fixings are behind the tweeter speaker cover, no need to disconnect battery for that job. |
Greg66 Member Since: 10 Nov 2010 Location: London Posts: 84 ![]() ![]() |
Thanks.
Dont think just disconnecting battery will help but a battery reset might ( big might by the way ) other than that bit of work but how about plugging mirror into other side see if it works there if it does than back to bad connections somewhere I guess. |
A happy ending. It works.
Know what you mean about that handle cable it could do with being a foot longer give you room to work but you got there in the end well done. |
