Home > Technical (L322) > Intermittent Vibration |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
I would have guessed it was the rear calliper until you said it was stripped and rebuilt already. Saying that I went down the route of just getting new ones just to avoid the chance that there is something else going on there.
6th Dec 2021 11:20am |
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 |
Must admit you've got me wondering now as the Calipers were done just after i'd replaced a Front Air Bag.
6th Dec 2021 4:32pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
I had a strange vibration in mine turned out to be the wheel bearing moving in the hub ( it had been replaced with an aftermarket changed to original and all good) As far as callipers go replaced mine on the rear with new as had problems refurbing so it could be that as it is intermittent |
6th Dec 2021 6:09pm |
klj Member Since: 24 Aug 2019 Location: Frozen North Posts: 66 |
A few suggestions..
6th Dec 2021 10:34pm |
Thanks for all the suggestions guys, will have a good luck and report back |
7th Dec 2021 9:48am |
chris595959 Member Since: 09 Jan 2012 Location: Brighton Posts: 61 |
Worn drive shaft , as you apply power it settles in an unbalanced position ie slightly out of alignment and vibrates . When in no power position its free to move and align in a different position may be the correct one or again out of alignment and it vibrates . |
7th Dec 2021 2:32pm |
Well fitted 2 new rear callipers this afternoon.
15th Dec 2021 9:09pm |
Meant to ask is it a vibration as in seats vibrating or a rumble as in a noise? If it is a vibration and you feel it in the steering wheel its front if you feel it in the seat its rear |
15th Dec 2021 9:33pm |
It’s a noise that can be heard quite loudly.
15th Dec 2021 10:23pm |
I had a similar situation after changing a wheel bearing on the rear it was an aftermarket one and it moved in the hub but only between 55 to 65 in my case new hub and problem gone might not be your issue but it might be again no vibration but noise |
15th Dec 2021 10:44pm |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 171 |
I would have thought a wheel bearing has gone, pulls out of the bearing race in a long slow bend at speed, I have had the same one a couple of cars and all 3 times it was the bearing. |
16th Dec 2021 6:20pm |
Thanks for all the suggestions guys.
20th Dec 2021 6:08pm |
Excellent news, and something new learned . Cheers ----------------
22nd Dec 2021 12:23pm |
