Home > Technical (L322) > TDV8 slight hunting
Chris1573
TDV8 slight hunting
Hi all, had a slight hunting at low rpm whilst driving through local town at idle speeds. No codes and it went as soon as I accelerated… being slightly paranoid and especially at the moment with the cold temps meaning I get the 4 degrees C bing that makes me jump every time and reach for the Gap IID before I realise Laughing I just wanted to ask if anyone has experienced similar and if there is anything to be checking… Thumbs Up
Car was warm at the time and I had just stopped at the co op to grab some milk. So it happened as I restarted and drove off. L322 2007 TDV8 3.6
Post #614672 4th Dec 2021 8:45am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Could be an egr sticking partially open. You can check via live values using the Gap iid. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #614676 4th Dec 2021 9:25am
LandyManSam
Ireland 2012 Range Rover Vogue TDV8 Santorini Black
Mine (4.4 TDV8) has also started hunting a bit at idle (barely perceptible on the dash but audible from in or outside the car).
Seems to only do it when warm and stationary. Aside from aforementioned EGR, is there any common fault that can cause this?
Post #620578 19th Jan 2022 1:32pm
