Home > Technical (L322) > Electric Windows Reset
Range Rover L322
Problem:
Electric windows not functioning correctly.
Solution:
Close the window fully.
Release the switch, then lift it to the close position for 2-3 seconds.
Release the switch.
Repeat the lift and release procedure twice more.
Test the window for correct manual and automatic switch operation. ...
Repeat the procedure on each window.
This just worked for me. 2012 L322 4.4TDV8 AB
Post #614564 3rd Dec 2021 12:01pm
JayGee
So you don't cycle the actual window up and down just the switch repeatedly to the up position? 2012 TDV8 Vogue (L322)
Post #614566 3rd Dec 2021 12:10pm
DrRob
I'm sure that's what I did too on my passenger side recently. It stopped going up so I just repeated holding the switch up a few times with the window still shut if that makes sense. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #614580 3rd Dec 2021 1:33pm
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
That’s what I did for all windows (and sunroof) after reconnecting battery. You will hear a faint click after a second or two holding the switch in the up position, presumably a relay, solenoid or whatever resetting. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #614600 3rd Dec 2021 3:32pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Use IID tool and it will do all the windows in one go. Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #615015 6th Dec 2021 12:53pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Great tip. I applied this yesterday to my car where two windows on the drivers side lost it. All good again.
Post #615029 6th Dec 2021 1:46pm
DrRob
Never thought of that Big Cry
Where is it in the menu please? Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #615059 6th Dec 2021 3:53pm
