Home > Maintenance & Mods (L405) > Dumb Battery Question
just to clarify the reasons for an aux battery,
my understanding is that for 2013/14 years JLR fitted a 90ah battery as a main.
the aux battery is a 70ah which is for 3.0 in cold climate countrys and standard for 4.4 engines..
in roughly 2015 when the stop/start was introduced the aux battery was reduced to a 14ah ..i think this was due to better engine tech and emissions..
this is from the WM,
https://www.fullfatrr.com/gallery/albums/u...attery.pdf ... - .- -.
Post #613779 25th Nov 2021 11:51am
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
Post #613782 25th Nov 2021 12:19pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
My 14 AutoBio 5L SC has the smaller motorcycle style battery. I checked the voltage when off and it read 13v when off and 14 with engine running. It was hooked up to the leads but my start stop is somehow not working (I don’t mind having no start/stop). But I get “low battery warning on the dash”. I just changed my main Bart like 3 months ago (did not have it programmed) and it reads 12.x volts when off and 13 with engine running. Is this normal? Why am I getting the battery errors…bc I didn’t get the new main battery registered? Or is the AUX battery malfunctioning with the read-outs it’s giving me? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #614337 1st Dec 2021 3:05am
its recommended to get the BMS reset so your FF knows you have a new battery...doing this should solve the dash errors, if it doesnt the you know that this process can be eliminated from your problem search... ... - .- -.
Post #614339 1st Dec 2021 6:59am
Friendee
Wales
Agree with Stan. I replaced both main and auxiliary batteries last Friday after ‘low battery warning’ on my L405. My ecu was then remapped to receive new batteries and warnings disappeared.
Post #614344 1st Dec 2021 7:56am
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Having to "tell" your FF it has a new battery makes me chuckle.
It's like emailing yourself to say you've had breakfast, after you've had breakfast Laughing What do I put here then?
Post #614347 1st Dec 2021 9:16am
Friendee
Wales
This practice is just another money spinner for JLR. Is the same applicable for the pollen filter to the new LRRR? 🤣🤣
Post #614349 1st Dec 2021 10:14am
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
[quote="GAC23"]Having to "tell" your FF it has a new battery makes me chuckle./quote]
AFAIK it's pretty common with many makes thesedays.
Post #614367 1st Dec 2021 12:31pm
horse86
Thanks for the replies guys. I’m do for inspection this month so I can have them register the new main battery I got a couple months ago. Hopefully this didn’t mess up the new main battery.
Assuming I don’t need to re-register the aux battery that’s been in there (still registers 13v engine off so didn’t replace it) 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #614407 1st Dec 2021 5:33pm
