Home > Technical (L405) > Battery Voltage - charging - CTEK
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
I'll bite... how do you know? SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #614288 30th Nov 2021 5:29pm
Aldogt3
Croatia
Measure the battery at the jump starter connection, order nre one and now i have two batteries😂
Post #614292 30th Nov 2021 6:14pm
luxmoggy
For me I was measuring under the hood it was more to see what the charger was doing. I am thinking of getting a battery sensor to attach directly so I can see the real level.
As I use the remote heating every morning at the moment. It is zero degrees here. I want to make sure the battery is good. SDV8 AB MY 2020
Post #614303 30th Nov 2021 7:38pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Sorry to resureçt an old thread but I also now have 2 batteries. Mad I don't understand why the readings are different under the bonnet. My original battery is 9 years old so probably due for changing anyway
The moral of the story is 'research on FF before splashing the cash......not after'
Post #691070 22nd Apr 2024 8:25am
The dual battery system is complex - and it's not clear (to me) which one is connected to the under bonnet posts - when the car is turned off. I expect it's the larger one under the spare, but don't know.
As soon as the car is 'on' the batteries may (or may not) be connected together, so all bets are off.
If you really want to know the batteries individually, then you need to check them directly.
A bit of info here, but not sure it will help - https://www.fullfatrr.com/gallery/albums/u...cables.pdf
Post #691074 22nd Apr 2024 9:37am
