Home > Technical (L322) > Wheel Speed Sensor error after hard cornering
G6 ROO
So for the 2nd time in the last 3 months I've had a C003A-25 (ECool rear right wheel speed sensor - general signal error occur after entering a corner a bit quicker than normal. First time was a left hand corner and second a roundabout (right hand). The error on both occasions is for the Rear Right wheel. Several associated errors are also generated as a result (HDC, stability control, airbag, abs, etc. etc.) Once cleared with IDD all is fine and working correctly.
Anyone else ever seen this at all and should a replacement wheel speed sensor be the starting point to fix it or is it potentially more sinister?
2012 L322 4.4 TDV8
Thanks
Post #614207 29th Nov 2021 9:59pm
