Home > Technical (L322) > Changing gearbox - need coding? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
Coding is only necessary with the 6-speed transmissions onwards, when the transmission ECU became integrated into the transmission.
28th Nov 2021 5:25pm |
winslo Member Since: 12 Sep 2011 Location: Morpeth, Northumberland Posts: 135 |
Hi
28th Nov 2021 5:26pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3108 |
If you’re changing the whole gearbox then yes it’ll need coding to the car.
28th Nov 2021 9:06pm |
Hi
29th Nov 2021 10:50am |
The module that will need coding it the black plastic one that is bolted directly to the mechatronics unit inside the sump.
29th Nov 2021 11:14am |
Macnaughton1 Member Since: 29 Nov 2024 Location: Fife Posts: 3 |
I am in fife and having trouble coding a second hand tcm unit could you help ? |
29th Nov 2024 8:15pm |
Or would the gap tool code the 2nd hand one to it ? |
29th Nov 2024 8:17pm |
I did mine using my IID tool.
30th Nov 2024 12:27am |
I have bought the tool mate I fitted second hand one then garage said no wanted all new parts is it easier if I fit a new tcm unit or will it still code with second hand fitted ? |
30th Nov 2024 9:59am |
You can definitely flash a used TCM with the IID tool.
30th Nov 2024 1:15pm |
