Home > Technical (L405) > Front bumper camera
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Front bumper camera
A stone chipped my front bumper camera! What are the odds... Can someone help with the part number for my model? Plenty of cameras on (UK) eBay, but I don't know which are compatible with mine (2019 P400e Vogue)... Thank you!
Post #613792 25th Nov 2021 3:14pm
try microcat maybe? ... - .- -.
Post #613827 25th Nov 2021 9:24pm
adara
Yes, I did, thank you, but as for eBay, they only say: LR052028 360° camera for Range Rover L405 from 2013, 6PIN.
Also suitable for vehicles with circular vision system: 1. DISCOVERY IV 2014-2015 2. RANGE ROVER SPORT L494 2014-2017 3. RANGE ROVER EVOQUE L538 2013-2017
So, will it fit RR 2019?
Post #613828 25th Nov 2021 9:41pm
just a thought...can you take the old one out and 'hope' there will be a part number on it.. ... - .- -.
Post #613830 25th Nov 2021 9:47pm
adara
Thanks, looks like a bumper out job...
Post #613860 26th Nov 2021 12:10pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I had exactly the same issue. This is the extent of removal required just to swap a 1 inch cube camera!
I know for a 2013 the part number is NLR 052 028
Hope that helps. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #613893 26th Nov 2021 6:39pm
Kot
The fleaBay seller states SDV8 VOGUE SE. PART NUMBER LR052028 - front camara ( ). LAND ROVER. RANGE ROVER. 5 Door Estate. Part Colour. RANGE ROVER 2013 -2021 Mk4 (L405).
Note this is off a scrapped car hence the price/offer requested
https://www.ebay.co.uk/p/26034600445?iid=175027011327
BUT be aware they could have their info wrong but worth a call to them ? 2018 SE SDV8 4.4 Byron Blue
Post #613902 26th Nov 2021 8:45pm
adara
Thank you, I sent him a message!
Post #613907 26th Nov 2021 9:50pm
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
OK, I'm going to hold my hands up here and state "I am stupid".
But what does the front bumper camera do? I wasn't even aware I had one!
Post #613908 26th Nov 2021 10:01pm
TJH1985
Talk to me about these ramps Whistle
Good investment? I’ve fancied some for a while. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #613909 26th Nov 2021 10:21pm
A RH camera has been on backorder for some 4 weeks now for my car... Rolling Eyes
Post #613926 27th Nov 2021 1:01am
adara
"The Range Rover has a parking aid system that operates in conjunction with the vehicle's cameras, and gives a 360 degree, detailed view of the vehicle's surrounding area and any obstacles in the vehicle's pathway, when parking.
The surround camera system consists of 4 cameras, located as follows: One is located in the centre of the front lower grille. One is located underneath each of the exterior door mirrors and one is located just above the rear number plate. The capacity to display several different views at the same time helps with various manoeuvers, from parking by a curb, to getting in and out of tight spaces. The integrated cameras also provide assistance when towing. Additionally, the 360 degree Parking Aid supports manoeuvering by employing sensors around the vehicle that automatically trigger when Reverse is selected or can be manually activated. When manoeuvering, visual graphics and audio feedback indicate proximity to obstacles.
In order to get full benefits from this driver assistance package, customers will need to know how to access settings for both the Surround Camera and the 360 degree Parking Aid.
If you wish to have this feature turn on automatically when performing a parking manoeuver, you need to make a selection in the settings. First, select camera from the Touchscreen to call up Surround Camera. Then the Camera settings pop up is displayed. From there, the customer is able to select Default Camera View and then add 360 degree Camera as a default view. "
Post #613930 27th Nov 2021 7:30am
RRV8SC
Well I have learnt something there!
Thanks Very Happy
Post #613946 27th Nov 2021 11:25am
ajac8
Yes brilliantt piece of kit. Comes with rubber blocks for lifting points and droppable end plates. Plenty of line to the control box. 3T capacity. Been faultless for a couple years now but only light DIY use.
I think I paid about £1900 delivered (30 miles from supplier). Ordered direct with Strongman. No need for a middle man and great service and support. You only need a Cat C or D breaker (back then anyway - worth checking spec now) and a few litres of LIC hydraulic oil.
The only thing I would say is the width is tight. You have to position a 405 exactly down the centre line. Lesser cars are a doddle.
The axle stands are just a bit of comfort for me.
Well worth it. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #613968 27th Nov 2021 2:50pm
adara
I managed to get an answer from the dealer, the surround cameras are all identical and the part number is LR098720, for Land Rover/Range Rover and for Jaguar (again, identical and similar to LR) T4K4171.
Post #623785 15th Feb 2022 3:28pm
