Home > Maintenance & Mods (L322) > Suspension not level at front
Leigh4571
Hi All,
Sorry to ask, an answer to this is sure to be on here some where, but I cant find it;
2007 3.6 V8 76k miles.
It is sitting 3/4 inch lower on drivers side than passenger, no change if been for a drive, left over night or been up and down access and off road height.
I don't know for sure when this started happening, but i did change the lower arm (where the sensor connects) a few weeks back.
Passenger 19inch from centre wheel, drivers 18 1/4 from centre of wheel.
Any pointers tip appreciated?
Is this the point I splash out on an Id tool to calibrate?
Cheers
Leigh
Post #613787 25th Nov 2021 2:00pm
dhallworth
Just check that the arm between the sensor and the lower arm hasn't been bent when you carried out the work on it and that it's connected properly.
Be surprised if it needs calibrating when it's the same sensor, etc.
Post #613810 25th Nov 2021 6:40pm
JayGee
The system has a +/- 10mm tolerance on each wheel before it will adjust so it may just be on the limit. 2012 TDV8 Vogue (L322)
Post #613812 25th Nov 2021 6:46pm
Leigh4571
Thanks forgot to say, I’ve checked the sensor after reading a similar issue but due to an incorrectly fitted sensor. But looks fine.
10mm I could live with, but this is 20-25 and it’s noticeable, especially when you’ve parked on a nice flat car park.
If I disconnect the sensor and move it down a bit with ignition on, then switch off, is it possible to trick the system set the it 25mm higher?
Cheers
Post #613818 25th Nov 2021 7:59pm
JayGee
I think it's time to think about buying that IID tool Smile 2012 TDV8 Vogue (L322)
Post #613821 25th Nov 2021 8:18pm
