![]() | Home > In Car Electronics (L322) > Bovee/Invery Issues |
My Bovee 1000 plugs straight into the socket via it's own captive cable and doesn't need an adapter. When I was looking into this there were reports of cables not working. 2012 TDV8 Vogue (L322) |
tpeat12 Member Since: 18 May 2020 Location: Glasgow Posts: 69 ![]() ![]() ![]() |
Hi,
Ah just looked at mine and the bovee can indeed be detached from it's cable. Given the Ivery does the same thing I'd suspect a wiring issue after the socket or the socket itself? On the audio controls you have the option of setting the tone controls individually for each source so worth checking to make sure these are all at standard settings. 2012 TDV8 Vogue (L322) |
I’d be surprised if it was the wiring between the socket and the amp but I could be wrong. Possibly moser Lilly it’s a problem with the socket (damaged by forcibly removing a previous cable), or it requires an original OEM cable. The number of pins on the Bovee cable and on the Invery cables are different which seems a bit strange to me. |
A quick update for anyone who is interested.
