![]() | Home > Technical (L405) > FBH Oddity |
spbee Member Since: 25 Jul 2021 Location: Cumbria Posts: 34 ![]() |
you could try fuse 27 in the passenger compartment fuse box, its a 5A and protects the fuel burnin g heater, TPMS and the centre overhead console.
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 130 ![]() ![]() ![]() |
I retro fitted remote climate last year as the FBH was on the car but had never been used as was not on the build sheet i fitted the antena and purchased a remote and updated CCF files but never got it to work as the light flashed on the dash and the blower came on same as yours but the FBH never fired, i got a fault saying auxilery water pump circuit open so i assumed because the pump had never been used which is on the end of the FBH the water pump had seized and if there is not water pumping around the system when the FBH tries to light it will fail as a safety feature and i also seem to remember after 3 fails you have to reset the FBH as it goes into Lockout.
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 233 ![]() ![]() |
The 5A fuse only feeds the FFBH receiver, not the FFBH itself. Check the owners manual for the fuse number and location (it may have changed during the production run so I can't give you a precise location). IIRC its fuse16 (20A) in the upper luggage compartment fuse box. Removing and replacing it will reset most of the lock-out faults on the FFBH.
Dshort86 Member Since: 28 Mar 2021 Location: Manchester Posts: 15 ![]() ![]() ![]() |
Thanks very much - checked those fuses and all is ok |
It’s an autobiography, plus the location and fit of the antenna and the fact the timed climate is on the media screen I would be confident it left the factory with it, is there a way I can verify that point? |
Thanks checked that fuse and all ok. |
Thanks all for your help and advice. Checked the fuses and all ok. Looks like I need to take it to the garage to get a code read |
rtobrienra Member Since: 08 Jun 2020 Location: Scotland Posts: 4 ![]() ![]() ![]() |
Thanks very much. Like you I replaced the water pump and still got the same codes. I rechecked the connectors and one of them wasn’t fully connected (the wires are very tight) hey presto it works perfectly using the remote fob. The only thing missing is the onscreen manual heat option. Any idea how I activate it on via the screen?
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
Silly I know but on some models the FBH via remote only works on a locked car.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
[quote="Dshort86"] Any idea how I activate it on via the screen?
