Home > Technical (L322) > Flickering lights.... |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
LED bulbs will cause flicker on light up. |
20th Nov 2021 3:58pm |
conor Member Since: 27 Aug 2021 Location: London / Ireland Posts: 146 |
Do you mean just on turning on the lights? |
21st Nov 2021 12:24am |
Ok, I have been doing a little more research.
21st Nov 2021 2:26am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Conor, the LCM will check the Cold monitoring and the Hot monitoring of all lights... This is why the lights flash on start up as the LCM send a small voltage through every bulb to check continuity and if you have LED bulbs fitted this voltage will send the LED beserk... |
21st Nov 2021 5:26pm |
Interesting, thanks Craig.
22nd Nov 2021 12:20pm |
It should only do it on startup for a second or two, and only if LED bulbs are fitted. You can stop it by turning off cold monitoring with a diagnostic tool, but again, only if LED bulbs have been fitted.
22nd Nov 2021 1:01pm |
Ahh ok..
22nd Nov 2021 1:34pm |
Mark T Boldry Member Since: 08 Feb 2019 Location: York Posts: 29 |
My 2012 Westminster 4.4 TDV8 has recently had a headlight flicker.. My lights are set to Auto, so when dark, they come on automatically, however, just over the past few evenings, the headlights will momentarraly flick off then back on again, they are off for less than a second, but on the dark small roads around here, it’s quite alarming when it happens...
30th Nov 2021 7:37am |
