![]() | Home > In Car Electronics (L405) > InControl Touch Pro Software Release S21B_21.37.2-778242 |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 814 ![]() ![]() ![]() |
Software Release Date: 2021-11-16
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1318 ![]() ![]() |
Thanks for the heads up |
You're welcome! I will call the dealer tomorrow, as none of the previous updates weren't available on any of our cars until they enabled them in TOPIx... |
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 491 ![]() ![]() ![]() |
Just looked to see if the update has been pushed to my car but sadly not |
As suspected, after a call to the dealer, the update was available and installed OTA in 15 minutes. The voice guidance is finally solved and the slope information is correct!
BizBo Member Since: 17 Aug 2021 Location: Lichfield Posts: 10 ![]() ![]() ![]() |
Do you just download and then turn off car and leave it for a bit?
1. Check for software update in settings, nothing. 2. Call dealer, give VIN, dealer enables the update in TOPIx. 3. Check again, now update is available, confirm, wait for download and install for approximately 15 minutes. 4. At the message: update will complete on vehicle shutdown, turn off engine and wait for another 15 minutes and then, 20-30 seconds after start, update confirmation message appears. Last edited by adara on 22nd Nov 2021 1:53pm. Edited 1 time in total |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 295 ![]() ![]() ![]() |
My software version is S19A_19.24.2-375121 - Can I jump to S21B.nnn or is that for newer vehicles? If I can I'll phone the dealer! FFRR SDV8 Autobiography |
All updated. Will see how this one goes! 2017 Range Rover Vogue V6 Diesel
The OTA updates apply to ICTP/ICTP Duo, so if you have that, it should work... |
Ocean53 Member Since: 14 Feb 2018 Location: Chichester Posts: 78 ![]() ![]() ![]() |
My car says it’s up to date s20! |
I asked the same thing. They said that there is a SOTA checkbox that keeps turning off and needs rechecked every time. So, just tell them: "Please enable the software update for my VIN." ![]() |
jvasquez8 Member Since: 14 Feb 2021 Location: Arlington, VA Posts: 11 ![]() ![]() ![]() |
Called my dealer today in the United States. They said they haven't received the update yet in the U.S.
