Home > Technical (L322) > 4.4 TDV8 Coolant Leak
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Had a slow coolant leak for a while, today I think I found the culprit.
Anyone had a leak from this....
It looks to be coming from where 7 is pointing to. The joint below that.
Post #613176 19th Nov 2021 6:06pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
I had one only last week that was slow leaking but was from number 8
I managed to get one new from fleebay relatively cheap for the whole thing
Arrived two days after ordering it 2016 4.4 diesel
Post #613184 19th Nov 2021 6:44pm
JNC
Have you got a link to item?
Post #613188 19th Nov 2021 7:01pm
Tdtj
https://www.ebay.co.uk/itm/RANGE-ROVER-4-4...635-2958-0 2016 4.4 diesel
Post #613193 19th Nov 2021 7:38pm
Tdtj
Don’t know if that’ll work for you not great with technical stuff 2016 4.4 diesel
Post #613195 19th Nov 2021 7:38pm
JNC
Perfect. Thanks.
I couldn’t work out what part it was from the diagram.
Didn’t fancy stripping it down just to diagnose.
I assume it came with a new seal etc?
Do you know how/why your one was leaking?
Post #613209 19th Nov 2021 11:20pm
Tdtj
To cut a long story short
I think the guy who had it before me disturbed the pipes
It was the tiny piece 8 that snapped in two can’t buy it separately 2016 4.4 diesel
Post #613213 20th Nov 2021 8:09am
Tdtj
Thats what came in the box. Minus the piece I needed
 2016 4.4 diesel
Post #613214 20th Nov 2021 8:13am
JNC
Perfect. Mine looks to be leaking from that top joint too.
Thanks
Post #613233 20th Nov 2021 10:53am
DrRob
Is the red thing a protective cap for delivery? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #613255 20th Nov 2021 1:49pm
Tdtj
Assuming so I haven’t removed it as I didn’t need to 2016 4.4 diesel
Post #613257 20th Nov 2021 2:08pm
JNC
Can you take a close up of the top plastic hose clip? The one in the middle.
I’ve had a closer look at mine and it appears to only have half a clip.
Hard to make out if it’s meant to be like that.
Post #615594 9th Dec 2021 11:43pm
