Home > Technical (L322) > MY 2010/2011 4.4TDV8 main fuse number identification?
abs66
Evening all.
I have been searching evrywhere to try and identify which fuse I can pull to disable the FBH on my 2010 4.4TDV8.
I think I have narrowed it down to fuse F13 in the engine bay fuse box using the wiki but as I can't find my handbook (SWMBO has tidied!) and I'm a bit nervous about just pulling fuses willy nilly.
Google, youtube and other various searches have not helped much, as all I can find is info on models either side of the 2010 -2012 MY.
I've got my fingers crossed one of you gents has done this in the past and can confirm F13 is correct.
Apologies if this is on the forum somewhere, but I can't find it.
The reason I want to disable it by the way, is that I suspect I have issues with both the FBH and heater control valves, which I can't fix at the moment.
Thanks in advance if one of you wise folk know the answer.
Cheers
Pete
Post #613182 19th Nov 2021 7:41pm
GraemeS
Australia
Yes, fuse 13 engine bay main fuse panel is for the FBH. I removed the fuse from mine.
Post #613194 19th Nov 2021 8:38pm
abs66
Thanks Graeme, that did the trick.
I must get round to getting the Heater Control Valve fixed with a repair kit but looking at it I'm not sure I'm up to the job. I'm currently searching for a how to video in case it is something I can do myself...no luck so far.
Thanks again for the reply, much appreciated.
Cheers
Pete
Post #614021 28th Nov 2021 4:22pm
