Home > Technical (L322) > Disconnecting battery
2010BlackL322
United Kingdom 2010 Range Rover Autobiography Black 4.4 V8 Santorini Black
All, QQ
Is there a special procedure to follow when disconnecting the battery on the L322, MY10
On the defender, you had to turn the key in the ign to disable the immobiliser, then remove it and had 30 seconds to take the neg cable off before the alarm would sound.
Sure the tech in the L322 is far, far more advanced, but wanted to check before I Censored off the neighbours
Thanks Check out my YouTube channel
https://youtu.be/UHBbLWZXw4A
Post #613046 18th Nov 2021 3:20pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Just take off the negative without the ignition on. Done mine a load of times, no issues.
Just make sure car is unlocked. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #613047 18th Nov 2021 3:29pm
Procedure is in the Workshop Manual which is in the WIKI... don't think it will set the alarm off but there is an explosive disconnect in there somewhere so you may lose a few fingers... Shocked Pete
Post #613048 18th Nov 2021 3:29pm
2010BlackL322
thank you! Check out my YouTube channel
Post #613049 18th Nov 2021 3:39pm
2010BlackL322
Shocked
Hmm... thanks Check out my YouTube channel
Post #613050 18th Nov 2021 3:40pm
Caesium
That's on the positive terminal and it's activated from a crash sensor so you'd need to be pretty dynamic with the terminal to trigger it.
This is why we disconnect the earth, no danger there. Christian.
Current Cars
2019 BMW X4
or
Post #613051 18th Nov 2021 3:43pm
I was just answering the question if there was a procedure to disconnect the battery....
Yes there is.....
The procedure is there for a reason... there are many shortcuts in the upkeep of a Range Rover but it's always best to have the correct information so you can make your own mind up if you wish to take short cuts....
It has been known for ECU's to develop faults when they have not been able to power down correctly...
On a fatty with no known problems then I expect just undoing the negative lead would be fine but when others are asking, and we have no idea of the health of their vehicle, IMHO I think it is best if they receive the "official" way to do it... Thumbs Up Pete
Post #613056 18th Nov 2021 4:10pm
briangunn
United Kingdom 2010 Range Rover Vogue SE TDV8 Buckingham Blue
The procedure is shown on the label on the slam panel:
Key off (well, ign off via the button on MY10 on cars), wait 120s for everything to do its shutdown process, then battery neg off.
There's no explosive disconnect devices on MY10 onwards cars.
Post #613072 18th Nov 2021 6:30pm
