Home > Maintenance & Mods (L322) > L322 Wiper Blades
Page 2 of 3 <123>
dhallworth
I'm not sure what's causing it.
Last night I swapped the blades between driver and passengers side and the fault followed the blade so I'm sure it's not the screen.
The rubber doesn't appear to be split upon inspection. It's odd on mine, they clear the screen going up but miss a big patch on the way back down right in front of my eyes.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #612217 10th Nov 2021 3:07pm
lukemx82
Just bought a set of generic aero wipers from ebay (thought it was worth the punt for £9) but having the same problem.
The quality of the blade and the rubber wiper all seems fine, but they just dont flex and follow the curve of the windscreen glass as well as the traditional type ones, so im getting a patch of glass on the drivers side that isnt being wiped.
Ive tried bending the blade to help it sit better on the glass but all it does is move the patch. Ive also swapped the blades from driver to passenger side and the patch is still only on the drivers side.
Our windscreens have quite a complex curve to them. On a windscreen with less of a changing curve they would be fine, and for the bits of screen that they do follow the wipe very well and very smooth.
The ones I took of are 5 years old and have gone hard so are chattering accross the glass, but even so its noticeable how they still flex enough for the rubber wiper to follow the shape of the glass across the full sweep.
Lesson learnt, will by a new set of traditional type ones.
Post #612738 15th Nov 2021 8:14pm
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Ordered a set of HQ and installed them on Saturday.
I don't rate them at all. They don't wipe properly and they slap on the drivers side a pillar.
I'll be replacing them with proper Bosch sometime soon. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #612742 15th Nov 2021 8:44pm
dhallworth
If you can find a part number for Bosch flat blades that fit can you let me know please?
I like the flat blades on the car but like you, am not at all impressed with the HQ ones.
Post #612748 15th Nov 2021 9:29pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
If they're hitting the pillar, the blade isn't the problem. They're either loose on the arm or the arms aren't set correctly on the spindles. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #612751 15th Nov 2021 9:50pm
MartinD
The blades I took off didn't do it and they're definitely set on the arm correctly.
I think it's just these blades - they don't seem particularly great. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #612754 15th Nov 2021 10:19pm
MartinD
David.
Certainly will do! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #612755 15th Nov 2021 10:19pm
dhallworth
I gave up today and ordered a set of Bosch 808’s from Amazon for less then 20 quid inc delivery.
Annoyingly, I can’t find the bits that you remove from the arms when fitting the flat blades. As the wiper arms on my car were rusty around where they pivot when you’re lifting them off the screen I used it as an excuse to buy 2 new wiper arms from Duckworths.
Post #612973 17th Nov 2021 7:52pm
MartinD
Didn't go with the Bosch flat blades then? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #612976 17th Nov 2021 7:56pm
dhallworth
I’ve tried 2 different sets of Bosch ones and they didn’t fit so I lost patience in the end Laughing 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #612977 17th Nov 2021 8:19pm
dhallworth
My new wiper arms arrived on Saturday morning and the Bosch 808 wiper blades arrived this morning.
I’ve swapped them both over and am pleased to announce that my wipers are now absolutely silent and are clearing the screen perfectly. Bosch 808’s can be had for around 12 quid a set on eBay so I’ve bought 2 sets and will keep one on the shelf in case they don’t last that long or the other car needs a set.
Post #613454 22nd Nov 2021 7:57pm
MartinD
Got a link for the ones you purchased? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #613459 22nd Nov 2021 8:24pm
dhallworth
Sure…
https://www.ebay.co.uk/itm/Genuine-Bosch-T...635-2958-0
I ordered these on 18th Nov and they were delivered today with Hermes.
Post #613460 22nd Nov 2021 8:26pm
MartinD
Did they come with the adaptors?
I've stupidly chucked mine out when I put the flatblades on Sad 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #613464 22nd Nov 2021 8:44pm
Bingo_123
same issue i have, my adapters were broken so threw them all while fitting Aero ones.
not very happy with the Aero ones, so will have to go back to Bosch flat ones.
just dont have the list/part nos of the adapters/plates i will need.
Can anyone post please.
thanks
Post #613539 23rd Nov 2021 2:31pm
Page 2 of 3 <123>
