![]() | Home > In Car Electronics (L322) > 2006-2009 head unit upgrade |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
I and a number of others use this https://www.navtool.com/land-rover-range-r...rplay.aspx
nemmi69 Member Since: 16 Jun 2015 Location: Peterborough Posts: 104 ![]() ![]() ![]() |
The unit, when you go to the link, looks wrong. Does not have the surrounding buttons as in the chat. What doesn't kill you is just bidding it's time. |
It retains the unit. It's what's on the screen that changes so you can toggle between the original and the new. It mirrors your phone. Check out the thread and the website.
Ignore the picture and follow through till you get the installation video which will explain it. John
Not sure I see that it does all the exiting functions. Also, doe this require an Apple phone? What doesn't kill you is just bidding it's time. |
Or Android John
Got to say, I am considering this
Wanderer83 Member Since: 01 Aug 2021 Location: London Posts: 27 ![]() ![]() ![]() |
Did you go for this in the end? Does the mirroring function mean you can control the iPhone/android via the OEM touchscreen? Or else you need to be handling your phone when driving which is not allowed? |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 293 ![]() ![]() ![]() |
I had the Navtool on my 58 plate, works off the touchscreen for Apple car play and was a fantastic bit of kit and straightforward to install.
RovingRanger Member Since: 20 Mar 2024 Location: London Posts: 4 ![]() ![]() ![]() |
Grateful to find this is 2024 as was hoping it would be possible! Thanks all |
ChrisandandieP Member Since: 24 Mar 2024 Location: Perth Posts: 5 ![]() ![]() ![]() |
The unit looks good, but what bugs me a little is the audio side. Using the aux plug and no bluetooth connection. I’m not sure if the aux input is better or worse than Bluetooth. Any thoughts or advice? |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
Using AUX means it can be susceptible to interference or ground loop noises (if no sound is on, the stereo can pick up noise from grounds of other equipment e.g. humming, or a high pitched noise in line with the alternator).
That’s what I do. I have an excellent adapter that connects immediately, looks ok, and sounds ok too, but I struggle with the idea of the aux connection being old fashioned and susceptible to interference. I am surprised that there isn’t a device that is a Bluetooth receiver and has terminals also, that can replace the CD changer and use the MOST connection for sound to the head unit. My CD doesn’t work and I want rid of it, but if is removed, I break the MOST link.
My apple car play that works 100%
Bluetooth usb thingy |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 104 ![]() ![]() |
The aux connection will always be better than Bluetooth because it is a permanent wired connection. I think 3.5mm aux connections are underrated in terms of quality. I use this in my L322 out of preference from my CarPlay unit. No background hum. Try it and see! |
