Home > Maintenance & Mods (L405) > Deployable Tow Bar
supershuttle
Deployable Tow Bar
Is there any maintenance that can be done on this? Mine played up this morning and it took about a dozen resets before I got it deployed - I think it was due to the cold. Geoff
Post #612665 14th Nov 2021 8:43pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Good question. I have assumed a bit of WD40 here and there may help but suspect it would attract some dirt etc. I'd be interested in the answer too. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #612674 14th Nov 2021 11:08pm
How's your battery, Geoff? If you have an IID, check for battery related codes?
Post #612678 15th Nov 2021 2:08am
try the deployment when at slightly higher revs and see if that makes a difference.. ... - .- -.
Post #612682 15th Nov 2021 7:35am
supershuttle
I never actually try to deploy with the engine running at all - something to try Thumbs Up
I've always assumed battery is OK as car always starts no problem but i'll dig out my IDTool and check - why didn't I think of that Bow down Geoff
Post #612686 15th Nov 2021 8:24am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
On mine, you can't deploy the towbar with the engine running
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #612689 15th Nov 2021 8:50am
this towbar diagnostic pdf from the WM suggests that the engine can be running?
https://www.fullfatrr.com/gallery/albums/u...TING~0.pdf ... - .- -.
Post #612690 15th Nov 2021 9:00am
Read the very last box of the diagnostics Whistle
Post #612693 15th Nov 2021 9:41am
you read all that pdf?
Mr. Green Thumbs Up
i suppose to eliminate a low battery voltage problem you'd have to connect a trickle charger.. ... - .- -.
Post #612695 15th Nov 2021 10:38am
I kind of skimmed it.
I'm paranoid that mine will play up just when I need it most.....
Post #612699 15th Nov 2021 11:00am
I would have to check but I don’t think mine will deploy with the engine running Stan… 👍
Post #612706 15th Nov 2021 11:59am
supershuttle
Thanks all, I haven't tried deploying with the engine running so I can't comment on whether it is or isn't possible BUT according to my IDTool the battery voltage is only 12.6v without the engine running rising to 14.4v at tickover. The document suggests you need 14v at least for the tow bar to deploy, so even though the car starts fine I bet on a cold morning it's even lower than 12.6v. Todays readings were taken on a Tesco car park while I waited for SWMBO to do a bit of shopping. I plan on simply leaving the tow bar alone (its deployed now) until the battery gives up properly. Geoff
Post #612719 15th Nov 2021 3:13pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
I seem to remember someone posting a link to a video of a failed unit being striped and rebuilt with a £2 micro switch that was sticky. letters not necessarily in the right order
Post #612722 15th Nov 2021 5:07pm
