![]() | Home > Maintenance & Mods (L322) > Suspension won't raise - compressor gone south? |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
I refurbished mine with a kit from XR8 and it’s been great since. Super quick to raise and lower. Christian.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35671 ![]() ![]() |
the FF is supposed to be higher at the front by one cm...why change it unless you want it to look level... ... - .- -.
It was 10mm higher than the spec so 505mm instead of 493 and the rears were a bit down at 475mm. 2012 TDV8 Vogue (L322) |
All seems OK today although it still takes quite a while to go from standard to off road height - >1min. Watching the live values on the IID tool screen the exhaust valve is opening 100% and the pump temp is not going over 80deg going from cold but if I lift it again it overheats. No pump operation in normal driving so it's not working to top up a leak. 'Gallery' pressure is >200psi when pump operating and holds at 37psi when off. Before I order a new pump is there anything else apart from a leak (not likley) that's causing a slow normal - offroad height change? 2012 TDV8 Vogue (L322) |
