Home > In Car Electronics (L322) > What are people doing for BT Audio in 02-05 sound systems? |
Matt Buckland Member Since: 27 Nov 2018 Location: Derbyshire Posts: 56 |
I have a 2012 Westminster, but I use the Amazon Alexa auto for music. Wired to the aux socket and powered by USB, BT linked to phone (and phone also BT linked directly to car as normal).
14th Nov 2021 9:29am |
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 |
I think it may be your ground loop isolator Conor? I use one on a cheapo Ebay bluetooth reciever and it works well for me. https://www.ebay.co.uk/itm/392734699305 FFRR 4.2SC/KTM 990SMT Current and cherished.
15th Dec 2021 12:04pm |
conor Member Since: 27 Aug 2021 Location: London / Ireland Posts: 146 |
Yeap.
15th Dec 2021 12:58pm |
Hi Folks, I just posted what I have done in a similar thread. https://www.fullfatrr.com/forum/topic61372-45.html
15th Dec 2021 1:43pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3112 |
Although yours is an 05 registered Supercharged it'll be based on the later architecture of the 06MY with the touchscreen so don't get the two systems confused as they're very different.
15th Dec 2021 3:19pm |
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 89 |
https://www.fullfatrr.com/forum/topic58324.html
17th Dec 2021 1:24pm |
Hi David, thanks for that.. i've been having a tough time dissecting what it is that I have, so thanks for pointing that out. I knew that my exterior setup was from the 06MY but wasn't sure about the interior/electronics. So... is it the case that while the general interior etc didn't get refreshed until a little later, but the entertainment system was updated.
That's a great setup Anvil and I like it a lot - may I ask when aux input you refer to/use in your setup? Is it the one towards the rear of the centre console i.e. in the rear, facing the rear passengers... as opposed to some other location I've not seen? Thanks a lot!
Thanks Muddycharles, it looks like a solid solution alright I might try out as a first port of call, prior to any cable hiding solutions.. Thank you kindly. |
29th Dec 2021 1:02am |
Yep that’s the one. Facing rear passengers. Get a 90degree plug to it doesn’t stick out. Loads of them on eBay. FFRR 4.2SC/KTM 990SMT Current and cherished.
31st Dec 2021 12:19am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
If you’ve not got rear screens just gut it and go after market. Current stable:
5th Jan 2022 11:51pm |
Cool, thanks for the headsup. Also, Anvil - notice you have a ground loop isolator in your setup there? It looks like the same one I had, and the sound was crap through it.. how do you find yours?
I have RSE, why does it make a difference..? Is it because you would lose all your RSE. In any case, when you go aftermarket, don't you lose all the OE software in the ICE system? I'd like to keep that. |
7th Jan 2022 11:51pm |
yea you'd lose it. I upgraded everything except the speakers as they are pretty good with a decent 6 channel amp. go hard or go home with that setup Current stable:
8th Jan 2022 1:52pm |
Hi Conor, I found it reduced volume just a little bit, but the quality is ace. No feedback and still great bass, treble and mid range. Still have all the rse in mine too! FFRR 4.2SC/KTM 990SMT Current and cherished.
9th Jan 2022 11:47am |
Ok, thanks a lot for that.. do you happen to have a link to the item you bought? I'd be curious to check it out. Thanks a lot.[/quote] |
10th Jan 2022 12:31am |
Hi, the exact link I used on Ebay has expired, but this looks to be similar and a similar price: http://www.ebay.co.uk/itm/Ground-Loop-Nois...2171319d08 FFRR 4.2SC/KTM 990SMT Current and cherished.
10th Jan 2022 12:39pm |
