Home > In Car Electronics (L322) > Which Fuse??? ( Solved?)
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
2007 TDV8 SE. Needed to change a blown bulb in the upper tailgate, the interior illumination. Popped the lamp, swapped to the bulb with a new led, lit up ok, then slipped fitting the metal reflector and shorted the circuit. Now both lamps out and the lamp by the Aux socket. Where is the fuse location? I have checked the owners manual and rave electronics section and no mention of the fuse. There is still power to the Aux socket. How can it be that hard?
So more reading and believe the LCM controls these lamps hence no fuse. went back to investigate more and they now work so there must be a self resetting fuse 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #612485 13th Nov 2021 8:37am
