![]() | Home > Maintenance & Mods (L405) > Corrosion issues? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1810 ![]() ![]() |
Being all aluminium, corrosion shouldn't be a problem, right?
Obligatory photos for Faceache
But look closer at the last picture...
That is quite frightening on a £100,000 car of that age. The other side was better, but still holed. Thankfully not structural, but strictly speaking, within 30cm of a suspension mount, and would be an MOT failure. And mostly hidden underneath the steel bracket from the front subframe mount... |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 89 ![]() ![]() ![]() |
Wow, thats not good.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
That’s a bit scary. One of the advantages of going from L322 to L405 was to not worry too much about rust….
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
With all the water , salt and |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
That, looks like electrolysis to me? dissimilar metals together with saltwater create electrolysis? |
Correct. Big steel spreader plate on top of each subframe mount, in direct contact with the body... |
If the body has some flex between the mating surfaces then the water will capillary between to start it off? boats, outboard motors,l that is in contact with salty water has a sacrificial anode.
Johnh Member Since: 08 Nov 2011 Location: Rugby Posts: 44 ![]() ![]() ![]() |
Even painting the bracket would help, on the to do list when purchasing a l405 |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Other manufacturers cope on cheaper cars than a RR, why dont RR do a bit of R&D into corrosion protection????? BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
What a depressing thread. My 2017 405 has had various bolts around the headlight mounts replaced due to galvanic corrosion (visible white furring) and one on the lower tailgate under the flap at the back of the tailgate (just rust there). The dealers said they were well used to replacing the bolts around the headlights. Scotland will be particularly bad for corrosion with so much salt on the roads and lots of wet weather.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3197 ![]() ![]() ![]() |
That's scary. Especially given that it's above the subframe and can't be easily inspected.
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 491 ![]() ![]() ![]() |
Definitely dissimilar corrosion going on there. Moisture forms the electrolyte and the fizzing begins. Sad to see a poor choice of materials there and a lack of separation between the steel and aluminium. 2017 Range Rover Vogue V6 Diesel
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 131 ![]() ![]() ![]() |
I think the problen in this thread on the L405 https://www.fullfatrr.com/forum/topic55957.html which i have suffered at great expense is down to two dissimilar metals and galvanic corrosion occurring or it might just be a bad batch of knuckles. |
WaterloggedFFRR Member Since: 22 Feb 2022 Location: Louisiana Posts: 6 ![]() ![]() ![]() |
Lost my 2014 ATB to corrosion. 70k miles. Over $30k in damage. Probably would have been over $40k had I done the repairs. Rusted sunroof drain flooded the vehicle interior.
