![]() | Home > General > 3.0 TD6 or 3.6 TDV8 - That is the question ? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
From your EGR thread… for completeness….
Kevhdkent Member Since: 27 Oct 2021 Location: Kent Posts: 69 ![]() ![]() |
Thanks for your input.
I never had an issue with the gearbox in mine so can’t help much with symptoms etc.
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
I had a TD6 which was a year old when bought, used it for 95% towing, 2 horses and box (c. 2.7T), was a great car for 100K miles and 11 years then gearbox went, got rid of it and bought a 4.4 petrol, again great towing vehicle but gearbox went on that, had that repaired and was all good again, now have a 4.4 diesel and perfect for towing, however would have the TD6 back anytime as it did all we needed it too, just budget for a gearbox refurb/replace, about £1500 all in and well worth it IMHO |
Extremely helpful Rosco, 👍
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3758 ![]() ![]() |
TD6 is fine, almost 80k trouble free miles in one, including a fair bit of towing at 3.5 tons with a twin axle Ivor williams DP120 loaded with cattle - absolutely no issue, yes the V8 diesel has a fair bit more poke and a better gearbox, but I would be happy with a TD6 again - I wish I had kept it as a second car, but then I have 5 other vehicles as well so it wouldn’t have got used. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
If your looking at a car to maintain at home then of course the TD6 is easier. Find one with a fresh'ish gearbox then all the better BUT, buy a 3.6 that has had the turbo's changed and has a good history, you will be owning a jolly nice 322 sir... |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2566 ![]() ![]() ![]() |
A point to note regarding the 3.6 and its turbos: there is a 2nd sump drain plug that is often neglected to be removed during an oil change. The 2nd drain plug drains a small reservoir that is used by the turbo oil drains and if the oil isn't drained from that reservoir often enough then sludge could accumulate which could then block or severely restrict the turbo oil drains.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
I had an X5, which has the same engine/gearbox as the TD6, for over 5 years, towed a twin axle caravan all over the UK & Europe, never had a problem..........but............mine was a one owner from new 85k fsh etc etc. I had the gearbox serviced twice in my ownership & treated her with respect when towing & she never missed a beat.
Thanks. Appreciate the input. |
zoso Member Since: 20 Aug 2014 Location: Ayrshire Posts: 79 ![]() ![]() ![]() |
I had a TD6 for a year between a Disco3 and a TDV8. Used it to move bikes around the UK - which it did with ease. Had a few minor electrical issues but I managed to fix them all myself - not difficult to work on. Preferred it over the Disco 3 and I still maintain it has the comfiest seats of any Range Rover that I have driven to date. Spares are easy to come by and not expensive. Wish I had kept it. 2017 4.4 TDV8 Autobiography
Probably the last post for a little while.
Wk52RR Member Since: 29 Dec 2020 Location: Devon Posts: 54 ![]() ![]() ![]() |
I had a td6 then moved to the tdv8. For me there isn’t much difference in terms of refinement at motorway speeds once the td6 has locked in top gear it’s really quite nice. The annoyance I had with mine was the gearbox wanting to change down at every press of the throttle and revving the engine far too hard. I’ve had the m57 td6 in in bmw saloons and it was a cracker in those but didn’t feel quite at home in the Range Rover. However I think if they made a Range Rover with the td6 and the zf 6 speed auto I’d have that over the tdv8.
