Home > Technical (L322) > FBH setting to pre heat the car |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Does the exhaust of the heater get hot? Can you hear the roar of the flame rather than just the noise of the fan? BMW i3 Electric Car
4th Nov 2021 2:06pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Should take a good 20 mins to warm up sir... |
4th Nov 2021 10:49pm |
rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295 |
Did it again this morning. It was on for about 25 minutes and I can hear the bit at the front working (Sounds like a very quiet hot air balloon when firing up).
5th Nov 2021 9:34am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
I turn up the temp dials the night before to max and I can confirm 100% that it makes a difference.
5th Nov 2021 1:19pm |
Yeah, I too have heard different things re the dial positioning. Mine never get much above warm. The standard run time is less on the last facelift than on the earlier models.
5th Nov 2021 1:44pm |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 168 |
Mine heats up regardless of the heating dial position, I thought the fuel burning heater ignored the dial setting and was a separate system and can only blow warm air through a bypass in the vent system. If the timed climate is on to cool the car then it’s just the fan that spins to blow cooler air into the cabin. I think the best thing to do if they are playing up is pull the fuse first, that should reset the FBH. Have you checked for the ticking noise at the rear of the car to make sure it’s pumping diesel to the heater ? Hope you manage to resolve it, it’s a great thing to have when the weather gets cold. |
5th Nov 2021 5:13pm |
Dean_C Member Since: 30 Apr 2021 Location: Lancashire Posts: 41 |
Mine does very similar fault too.
6th Nov 2021 7:45am |
There isn’t loads of heat come out, just enough to take the edge off and defrost windows. At least that’s how my 2 cars have been.
6th Nov 2021 9:01am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3196 |
Not sure if mine works but for a big engine it sure gets up to temps quickly. I have the remote as well but it doesn't seem to connect. Does the system need switching on in the car screen menu for this to be enabled? 2012 TDV8 Vogue (L322) |
6th Nov 2021 10:56am |
First thing to do is look to see if you’ve got the receiver fitted, it’s in the right hand cubbyhole in boot. I think it’s got t90 or t91 written on it.
6th Nov 2021 11:18am |
Just looked and it's a T91R. Followed the WIKI instructions and the first thing I found is a flat battery code on the fob LED even though it reads 3v so I'll take it from there. 2012 TDV8 Vogue (L322) |
6th Nov 2021 5:05pm |
Yep. Ticking at the back, noisy thing at the front and a solid green light when I turn it on with the fob. Maybe I should try pulling the fuse for it to see if it resets any issue. Tried it yesterday morning after putting heating and vents on full and it was still cold. The car seems to warm up quicker than if I didn't have it on but not by much. (from driving it) |
7th Nov 2021 8:12am |
Removed the fuse and reinserted it.
7th Nov 2021 10:26am |
Does the SC have a pre heater or is it just a cooling function (Green light)? 2012 TDV8 Vogue (L322) |
7th Nov 2021 11:32am |
