Home > Technical (L322) > Coolant leak.
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Coolant leak.
I started having coolant leak after changing the coolant.
Today i found a spot in front of the engine.
 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #611786 6th Nov 2021 10:53am
Discotigger
Hi Umitbat,
Have a look at the pipe that runs to the EGR cooler. I had a coolant leak, long before my Changeover valve problem and my indy mechanic traced the leak down to that pipe. He said it had perished so badly that it had 'turned to mush'. Replaced the pipe and no more coolant leaks.
BTW, got the new changeover valve fitted and the FFRR is now toasty warm. Did a wedding run for a friend of mine last week and she loved the RR experience, especially as I had my best suit on and a chauffeur's cap. It made her day!
Post #611808 6th Nov 2021 12:47pm
umitbat
Lovely photo!!!
Thanks for info.
Is it hard to access??
My changeover valve is working just after some sanding and cleaning too.
Best wishes!! 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #611822 6th Nov 2021 4:26pm
umitbat
This guy is leaking then?
Hope it is the hoses.
sold 06 td6 160k
Sold 03 td6 260k
Post #611911 7th Nov 2021 3:58pm
Discotigger
Think the egr cooler should be okay, but check the hoses to and from it. It's a bit of a sod to get at on a 4.4 TDV8, but not sure of its location on the 3.6 engine.
Post #612253 10th Nov 2021 9:14pm
