![]() | Home > My Range Rover > Crazy newbie. Sight unseen with inactive suspension 4.2 SC |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Ahhhh fair enough mate. Covid is a horrible disease too catch that's for sure. I had a stint in intensive care with it.
conor Member Since: 27 Aug 2021 Location: London / Ireland Posts: 146 ![]() ![]() ![]() |
Oh they do look nice.
I'll get you some tomorrow but I left the original mud guards on and they fitted straight into it |
Perfect thanks.
Hey David, I read this earlier, but missed the reply as I was doing the others! The issue with the radio is a frozen "Land Rover" splash screen and flashing amber LED on the power switch. I had disconnected the batter to test out the air suspension for leaks etc and that is what greeted me when I re-connected. I doubt the bluetooth is shot.. I need to try the "holding two battery terminals together" trick to see if that resets anything. If not i'll be bypassing bluetooth module via the fiber trick.. That's a verrrry interesting prospect about the 3 wheels, especially considering I have the fourth sat in the spare wheel well. I would be very tempted to purchase these from you. I will PM you as I doubt the rest of internet really cares for the discussion.. lol. Cheers Conor |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
... but how does something like this happen?
Conor
Haha and a bit like me at times too maybe... like that time I agreed to buy a faulty L322 without even seeing it... err LOL!!
Well you said it buy don't knock it mate. I done the same. All I see was the photos on ebay. Sometimes it works out some times it don't.
Awesome thank you.
If probably just hold on till your back here mate before you order them. Like you say you'll only have too pay the import tax.
Yea, I think i'll hold out alright.
Quick update..
The car had been sitting a week and has remained like this - I think it's safe to say that the rear air suspension setup has no leaks. Never mind the black tape - I poked a hole in the rust and don't want any water ingress while the car is waiting to be brought in.
I have also made a little errrr... progress on the heating front... Well, I had the car running for a bit while I was at it today, say 20 mins (ish). No hot air at all, but once things got warm, the temperature needle shot up to near max. When having a look around under the bonnet I noticed the coolant was low. Grand needs topping up. I read somewhere that if the coolant is low it can't reach the rad. I don't think mine is that low. When leaving, I killed the engine before closing the bonnet. When closing, I could hear a kind of hissing... like something leaking under pressure...! Then for some reason I opened the coolant expansion bottle and the coolant started bubbling up. At first, I was like, HEAD GASKET!! One of the guys reckons the thermostat is stuck closed which means the coolant isn't going through the heater matrix for hot air, or through the rad to cool it? He reckons I could take the inside of the thermostat out, to open it and see how things change.. along with topping up coolant. Thoughts.. How much is a genuine LR thermostat? I see there is an aftermarket one there somewhere for less than £15.
Sooo.. On the topic of error codes. I scanned with IID and got loads and loads of stuff.. I cleared them and scanned again, and what I received is shown below. Please keep the following known issues in mind:
In reviewing looks like everything is in order really. Along with the above items, looks like just a few bulbs - hopefully it's just bulbs and I don't need whole headlights lol. I wouldn't be bothered about the TMC and TV errors. VIN SALLxxxxxx Model L322 - Range Rover 2006 Vehicle scanned on 7 Nov 2021 12:32:13 IIDControl 3.0.0 Build 84 Android - IIDTool BT V3.0 B2643 ARM-Airbag 0x5 Front Left Thorax Airbag BPM-Body Processor 0xA0 Driver door mirror heater: open circuit FEM-Navigation U1A00-87 (2F) Private bus circuit - Bus signal/message failure - missing a message ( on 07-11-2021 12:31:09 at 720643 km ) LCM-Light Control 0x52 Check brake fluid fault 0x7A Front left sidelight defective 0x7B Front right sidelight defective 0x92 Rear left foglight defective TMC-Traffic Message B1A56-18 (2F) Antenna circuit - General electrical failure - circuit current below threshold TVM-Television B1D58-13 (2F) Television output circuit - General electrical failure - circuit open [/list] |
