![]() | Home > Technical (L322) > Change brake pad bolts, etc. when fitting new brake pads? |
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
I recommend you have the pins available before you start replacing the discs and pads. When I replaced mine I didn't and the existing pins were seized solid and one was totally destroyed in the process of removing the pads. 2012 4.4 TDV8 Vogue SE Current
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 453 ![]() ![]() ![]() |
Bearmach do a brake pad fitting kit, it's a large pad retention pin with bolt securing and then two smaller pins which secure the anti rattle spring.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 331 ![]() ![]() |
Is there a punch with an inverted conical end to push them out? |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 ![]() ![]() ![]() |
Yes, in my toolbox! If you look on Ebay, one can find extended length Torx bits, I buy them and spin the end on a grinding wheel to dish the end. You might be lucky and find a set of Pin Punches someone is getting rid of. Make sure they are Tool Steel. Standard lengths of Tool Steel from an Engineering tool supplier like Cromwell should have what you want. Even a four inch nail can be helpful. |
