![]() | Home > Wheels & Tyres > IIDtool tool coding for larger tyres |
What values did you change? 2012 TDV8 Vogue (L322) |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
Just the wheel size and width, will check in morning what circumference it is set at, as you stated earlier the overall wheel size is the same as yours.
Set the digital speed display to on and added 12mm to the rolling radius - ABS value. GPS app on phone, digital speed readout and the dial all read the same speed i.e the same as before so this value is not running the speedo. I wonder if dealers have the facility to reprogram the car for different wheel sizes through the official workshop software? 2012 TDV8 Vogue (L322) |
Set the MSP-IPC to 32 but the speedo now slightly under reads the GPS true speed and I found a post on a US forum that corroborated this and they recommended setting the number lower so will try 30 tomorrow. 2012 TDV8 Vogue (L322) |
Fixed! |
Took a long trip with it set at 29. Just about perfect IMO. Indicated 70mp is 67/68 on the GPS @ <1400rpm. Cruise sets accurately. Not so sure about DTE and other trip functions but these are not important. 2012 TDV8 Vogue (L322) |
Nismotec Member Since: 27 Apr 2019 Location: Dorset Posts: 54 ![]() ![]() |
Sorry to jump in to this post, but can someone tell me how to get this wheel size menu on my Gap? I cant say ive seen it... unless its because my old 04 TD6 doesnt have the feature?
Car configuration - instrument pack. 2012 TDV8 Vogue (L322) |
