Home > In Car Electronics (L322) > Trailer led flash |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
A bit confused but I think I am right that the bulb-out system caused the trailer leds to flash and can be turned off with diagnostics. What module controls this, LCM? Car is a 2007 TDV8. 2007 TDV8 VSE
28th Oct 2021 2:53am |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
Correct mate. Best way is too add a pair of inline resistors so it fixes that issue. |
29th Oct 2021 6:47pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
The resistors go in parallel to LED not inline (series). BMW i3 Electric Car
29th Oct 2021 7:24pm |
My led trailer lights work and the car does not show any problem. My issue is The bulb out system fire a 2volt pulse out to test the bulb and it causes a flash on the led. So the question is, can I turn off the cold test via diagnostics? If so which module has the setting 2007 TDV8 VSE
30th Oct 2021 2:19am |
I'm not sure on the Range Rover, on my Touareg with the diagnostic tool it was an option 'cold bulb test'. If it's not an option on Range Rover it wouldnt be difficult to add a resistor and capacitor combination to absorb the pulses and stop them displaying. BMW i3 Electric Car
30th Oct 2021 3:47am |
