![]() | Home > Technical (L405) > Battery Voltage - charging - CTEK |
recordman Member Since: 08 May 2013 Location: Kent Posts: 117 ![]() ![]() ![]() |
I use an MXS 5.0 on the underbonnet terminals and it works perfectly. 2017 SDV8 Autobiography |
What he said 👆🏻 |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 492 ![]() ![]() ![]() |
Thank you for that. I have it on charge overnight and during the day tomorrow. I will check the voltage in the morning and see where it stands. SDV8 AB MY 2020
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 185 ![]() ![]() ![]() |
Yes, me too, no problem |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 773 ![]() ![]() ![]() |
Same here concerning the MXS 5.0 and the under bonnet posts. I sometimes find I need to leave the car on charge for a couple of days before it reaches the fully charged state. Kev
OK.. Voltage after 11 hours is 12.34V - charger connected and running. I don't need to drive the car until tomorrow so I will leave on charge. I am wondering if my charger has a issue, I will ask my friends to see if I can borrow another one. SDV8 AB MY 2020
So when I connected the multimeter just now it is still reading 12.34V. The charger said in was in the Float stage and in the manual it says 13.6V. So I think my charger has the issue. If anyone has a multimeter I would be interested in their voltage reading on the terminals. SDV8 AB MY 2020
I have a little BM2 battery monitor across my primary battery that constantly logs my battery voltage and uploads the results to my phone whenever I walk near the car.
I had an MXS 5 fail after many years of use. It would only display battery voltage and showed no signs of charging. Bought a couple of ALDI chargers, never had any problems to date. |
Thank you for that. I will see if I can borrow one. Then I will look for a new one. SDV8 AB MY 2020
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
sounds normal to me for normal battery (non-AGM) |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1310 ![]() ![]() |
I agree with ur20v
New charger I can see the voltage climbing on the multimeter… SDV8 AB MY 2020
Aldogt3 Member Since: 05 Mar 2018 Location: Zagreb Posts: 15 ![]() ![]() |
You should measure battery voltage in the battery (remove the spare tire), not in the jump starter connections under the bonnet. The jump starer connections don't show it. Ask me how I know😂 |
