Home > Maintenance & Mods (L322) > Squeaky seats
supershuttle
Squeaky seats
Both front seats squeak when you move about on them. On investigation it's not the seats but side trims with all the adjusters on, you can just get hold of them and wiggle them about and they squeak (a lot). Anyone experienced this and probably more to the point has anyone got a cure?
It's not a big deal but it;'s getting increasingly irritating now I've noticed Neutral Geoff
Post #61044 19th Apr 2011 8:34pm
A bit of cloth wedged down the gap does the trick - just stop the 2 surfaces rubbing against eachother
Post #61053 19th Apr 2011 8:56pm
you could spray some silicon lubricate down there... ... - .- -.
Post #61079 20th Apr 2011 8:13am
supershuttle
Thanks for the suggestions guys,
I drove to work today in a squeak free world. Just carefully stuffed half of what I believe used to be called a "J-Cloth" into the crevice (so to speak) between the plastic and the leather it has disappeared and so has the squeak. I might try the silicon spray on the passenger side but am not sure what exactly to use.
I also noted that one on the screws is missing so I might take the panel off and see if I can't do something "nicer".
Anyway Cheers Thumbs Up Geoff
Post #61088 20th Apr 2011 8:32am
supershuttle wrote:
....a "J-Cloth" into the crevice
Rolling with laughter Rolling with laughter
Post #61096 20th Apr 2011 8:58am
