Home > Technical (L322) > “Only Normal Height Available”
DeeJay
South Africa 2011 Range Rover Vogue SE TDV8 Fuji White
The air suspension in my vehicle works*, every time, seamlessly, Im also happy with the way it self levels taking heavy loads or towing. I notice no sagging after the vehicle was left standing for days/a week, I notice no compressor working when it shouldn't.
* Occasionally after changing into Normal, either from Access mode or from Off Road mode, the vehicle will display an error “Only Normal Height Available”.
* Occasionally after changing into Normal, either from Access mode or from Off Road mode, and after engaging the Cruise Control, the Cruise Control will de-activate and will display two errors “ACC Not Available”, and “Only Normal Height Available”.
...these aren't immediate after changing into Normal, it would be anything between 5 to 10 minutes. There is a cure: stopping at the side of the road, switch off, start, and off we go no problems (seemingly) - not ideal.
Why would this happen? 2011 Vogue SE 4.4 TDV8
Post #610371 26th Oct 2021 6:29am
There are many reasons why this could be happening. Do you have access to an IIDtool, or any other diagnostic tool to get the error code?
As an example, I had a similar issue and it was the reservoir tank that wasn’t filling quickly enough due to it having rusted through and had a leak. I don’t imagine that will be your issue. Got - 2017 SDV8 Autobiography in Loire Blue
Post #610381 26th Oct 2021 8:04am
mjdronfield
I’m guessing that if it can’t be sure the car is actually sat level or at the right height, it will disable the cruise as the adaptive radar can’t be guaranteed to be at the right angle to to road…. So it won’t trust it’s readings either.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #610383 26th Oct 2021 8:09am
DeeJay
When this happened one time i opened the 4x4 Info page so see if maybe it would indicate a height issue on one of the wheels, and it displayed the vehicle to be level. It also self levels quite nicely with heavy loads. And so im reluctant to assume a height sensor issue. 2011 Vogue SE 4.4 TDV8
Post #610386 26th Oct 2021 8:18am
DeeJay
Negative 2011 Vogue SE 4.4 TDV8
Post #610387 26th Oct 2021 8:19am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Check out the wires on top of the suspension tops under the bonnet if you have adaptive suspension? they could be reconnecting and the parting and you cannot see it? the wires are very thin and get brittle. There is a part replacement from the main dealer?
Post #610399 26th Oct 2021 10:29am
DeeJay
The wires for the adaptive suspension has been fiddled with in the past, I dare not take it apart to try do a better job with the tape already used for fear of messing it up even more, especially if I dont experience a problem with it. Im just not quite catching how an EAS activation can trigger an adaptive suspension fault linked to the wires and the error messages I see - care to elaborate pelase? 2011 Vogue SE 4.4 TDV8
Post #610411 26th Oct 2021 12:28pm
Tinman
The trouble will knock out the adaptive cruise as well and something else with the braking it`s like they are all interconnected?
If you have tape on the wires they may have been soldered which will break again I know because I soldered mine before I replaced the wires?
After replacement no more problem Thumbs Up
It`s a known fault?
Post #610413 26th Oct 2021 12:41pm
DeeJay
This is an attempt at getting the post to the top of the forum again in case a knowledgeable person didn't see it before. Thanks. 2011 Vogue SE 4.4 TDV8
Post #612866 17th Nov 2021 7:28am
DeeJay
Sure it is a known fault with the appropriate "Adaptive Dynamics Fault" warning message. I do not get this warning message. If it was the case that I need to relook at the wires wouldnt the Adaptive Dynamics warning come up in other situations? 2011 Vogue SE 4.4 TDV8
Post #612867 17th Nov 2021 7:33am
