Home > Technical (L322) > TDV8 Mahle Oil Filter Question
stevepen
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
I've replaced the oil a few times now and always used a Mahle oil filter. My question is that it comes with 3 O rings. The large one for the screw on holder but what are the 2 smaller ones for? I can't see anywhere they can fit and no sign of any old O rings anywhere. 2011 Vogue SE TDV8
Post #610318 25th Oct 2021 12:49pm
Baltic Blue
Not needed…. Presumably the same filter is sold for a different engine/ car that needs them.
Post #610321 25th Oct 2021 1:12pm
suburbanspaceman
United Kingdom 2011 Range Rover Autobiography TDV8 Ipanema Sand
I’ve just serviced mine for the first time and thought the same. Rightly or wrongly whoever serviced it previously had used the thicker of the two washers on the base of the canister above the water drain disk, so I followed suit.
Cheers
Post #610327 25th Oct 2021 3:02pm
stevepen
suburbanspaceman Thanks for the info. I'll look at that on the next change. 2011 Vogue SE TDV8
Post #610328 25th Oct 2021 3:11pm
suburbanspaceman
My mistake I misread the thread title. I was talking about the fuel filter.
Post #610376 26th Oct 2021 7:17am
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
The extra o rings are for a Merc , uses same filter in different housing so not used on RR, just the big one .
Post #612310 11th Nov 2021 2:12pm
