Home > In Car Electronics (L322) > Begging for help ( audio ) |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 683 |
Well, I know absolutely naff all about the electrics on here, but i'll give my two'pennyworth.
22nd Oct 2021 7:15am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
I recommend you give yourself some time. You will need to remove all the modules from the rear of the car, dismantle each one so that you can check the circuit boards (PCBs) for corrosion/water ingress. Give a good clean with electrical contact cleaner and a toothbrush or similar soft brush. Also check all the contacts in the connections. Then see if that has helped. .
22nd Oct 2021 9:14am |
Dacton Member Since: 22 Oct 2021 Location: United Kingdom Posts: 4 |
I have now stripped the rear amps and checked the PCBs, tv tuner has abit of corrosion on it rest is clean I have found some droplets of moisture on the floor, might send the amp off to be tested by a independent shop and not tell them it’s a Range Rover lol |
22nd Oct 2021 10:59am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Baris used to be a good guy to deal with on these things. He put a bluetooth module in mine. Still didn't drown out the noise of the TD6 though.
22nd Oct 2021 11:39am |
Baris won’t touch it |
25th Oct 2021 11:30am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
Baris specialises in the earlier BMW based non touchscreen system.
25th Oct 2021 11:41am |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
Whereabouts are you? |
25th Oct 2021 11:43am |
Makes sense… I’m in Bournemouth, Dorset but willing to travel to sort this out |
25th Oct 2021 3:23pm |
Sorry, my mistake. I thought you had the earlier BMW stuff. |
25th Oct 2021 4:54pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
I'd say best way you'll be able too get to the bottom of this is find someone who's got the spec motor with yours, offer them some wedge for the day and see if you can swap some of the modules, amp etc with a known working one. Least that way you'll be able too figure it out.
25th Oct 2021 5:19pm |
