2009 TDV8 N/S Front Wing Removal | |
Hi all,
After an eventful day replacing the air con condenser, I thought I'd have a go at removing the nearside front wing, as I need to replace the front bumper clip (hit a post...). I'm totally stumped - I've removed the T30 bolt along the top (all four), and the 10mm bolts behind the plastic side panel. The back of the wing where it meets the passenger door seems to be stuck on with foam, which isn't helpful, but are there any other bolts at the front to remove? I can't see anything obvious, so does this mean I'm going to have to remove the wheel arch liner?
 | Click image to enlarge |
