Home > Maintenance & Mods (L322) > Brakes gone
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Brakes gone
Hi all
2004 TD6 L322. Brake pedal went to floor on way home.
Just managed to get it on drive and have fluid pouring out from half way along N/S
There’s a black plastic (shoebox size) cover held up onto the chassis rail with 2 bolts on N/S. halfway along between front and rear doors.
I’ll unbolt it tomorow and hope there’s a valve or union or something under there?
Can’t see the route the brake pipes take from a quick glance.
Any clues?
Cheers Accept, some days your the pigeon, some days your the statue!
Post #609858 20th Oct 2021 3:40pm
mjdronfield
They all come down at the back of the passenger side wheel arch, sort of under the battery, then run along the outside edge of the passenger side.
There is a join as it comes down inside the front wheel arch. Get them all changed…. Must have corroded through….
Excellent write up in the Wiki….
https://www.fullfatrr.com/forum/topic25799.html
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #609863 20th Oct 2021 3:56pm
Boydonegood
Oh your an absolute star as always. Thank you so much Accept, some days your the pigeon, some days your the statue!
Post #609866 20th Oct 2021 4:03pm
