Home > Technical (L322) > Heater not heating at all!! |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Oops smt not right with mine.
19th Oct 2021 1:45pm |
I had some leak due to my mistake so i deleted the post sorry... 2010 3.6tdv8 180k km.
19th Oct 2021 2:18pm |
I connected all hoses on the replacement valve with a T connector.
20th Oct 2021 10:01am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
20th Oct 2021 12:23pm |
Great news at last!!!!
20th Oct 2021 12:30pm |
20th Oct 2021 1:10pm |
I'm just doing a little bit of double checking myself, as there are two plunger seals in the valve. There is the one that you can see in your photos, the one that was swollen and you flattened, then there is one in the bottom of the valve.
20th Oct 2021 1:45pm |
Ideally you want to get a repair kit like this, with two rubber seals, o-rings and membrane seal. You don't need the plunger, as yours will be different to those shown on the kits and your plunger should be okay to reuse.
20th Oct 2021 2:30pm |
Probably it is pinned inside each other and they are pretty welded.
20th Oct 2021 7:44pm |
Hi again.
21st Oct 2021 3:46pm |
Is it normal that the turbo hoses are cold?
21st Oct 2021 7:03pm |
It shouldn't cause any problems leaving the tee piece connected as you have done, you don't need to blank off any lines as the coolant will circulate normally round the system, regardless of the bypass of the valve. The only difference in blanking the FFBH return line into the valve will be that all the coolant circulates through the engine.
21st Oct 2021 10:51pm |
If you feel the need to blank off any line, then blank off the top left hose into the valve, as shown on the picture and connect the hot coolant line from the engine into the outlet line from the valve.
21st Oct 2021 11:08pm |
Yes those two.
21st Oct 2021 11:46pm |
