Home > Maintenance & Mods (L322) > Front bumper alignment |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
Getting through a few jobs on my latest project, is there a quick fix for this or does the bumper have to come off? Its only the drivers side edge that's protruding, the rest is all fitting nicely.
17th Oct 2021 3:35am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
I would imagine it's had a little knock and bent the inner bumper section, it's easy to pop the bumper off and check/straighten it, I did it several times after using the front bumper on fatty off roader....
17th Oct 2021 10:06am |
Wayne's is the earlier model, the bumper is thinner and although that looks like a dent it isn't it's the shape of the bumper, his is just not in line with the wing...
17th Oct 2021 10:14am |
17th Oct 2021 10:43am |
Finally got around to looking into this, turned out as simple as poor-fitting from the last person to mess with the bumper. So this one-owner car, only ever been to the supplying dealer for work had one screw holding the RH wheel arch liner in place, the screws on the under-engine cover to bumper all missing, both headlight lower screws missing, the tow eye cover held on with self tappers and the bumper not engaged into the slide on the driver's side plus the outside temperature sensor wedged in a gap, not affixed to the rear of the grill. I also took the opportunity to fit some new 5000k hid bulbs as the headlights were out.
9th Nov 2021 4:47am |
