Home > Technical (L322) > Odd coolant behaviour |
nick4275 Member Since: 28 Sep 2018 Location: Bewdley Posts: 65 |
I had this fault, turned out to be the coolant level sensor. It's stuck into the bottom of the coolant expansion tank on my TDV8 3.6, not sure if the 4.4 is the same. It was an easy fix, providing your hands resemble those of Snow White's buddys ! |
14th Oct 2021 7:00pm |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 345 |
It’s not the fact I’m getting the message it’s that some days the coolant is inches lower than the low mark other days it’s ok, where is it going 2012 Range Rover Westminster 4.4 TDV8
14th Oct 2021 7:08pm |
Ah, sorry, its been a long day !
14th Oct 2021 7:22pm |
No oily sludge, no white smoke I’ve had it pressure tested, just very odd one day the level
14th Oct 2021 7:40pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
I had a similar issue last year, where the coolant would be fine for a couple of days then would drop. There were no obvious coolant leaks but, whilst my indy mechanic was fitting new gaskets on the oil cooler, he noticed that a hose that runs to the EGR Cooler was badly perished and 'mushy'. He replaced that hose and the coolant level has been fine ever since.
14th Oct 2021 8:25pm |
My problem is it’s low one day then the next it’s ok so it’s not leaking as it wouldn’t return to normal very odd indeed 2012 Range Rover Westminster 4.4 TDV8
15th Oct 2021 11:17am |
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 34 |
Noticed the same on mine and find it very odd. Where would it be going? 2011 Vogue SE 4.4 TDV8 |
16th Oct 2021 8:47pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Yep, I'll join in... both of the ones I've had have done it... I put it down to one of those things....
17th Oct 2021 10:10am |
