Home > Wheels & Tyres > Running L405 on 19”
Running L405 on 19”
Has anyone put a set of 19” on their 405?
Just curious as I have a set of style 15 on winters in the shed.....
They should fit as the brake setup is pretty much the same as the 322, however the bell on the brake disc on the 405 is smaller so I suspect that a different offset will be required? There is nothing that can't be fixed with a hammer😜😜
Post #558338 20th Jun 2020 9:02am
There was a 19" option for the L405 - they look a bit like Cayenne wheels IMHO
Seems to be some debate about whether they'll fit on the SDV8
There's a photo & some background here - https://www.fullfatrr.com/forum/topic48293.html
Post #558340 20th Jun 2020 9:23am
CS
The 2015 brochure I have says the 19" option on the 405 is for TD6 only. I took it that the style 15s would not fit the 405, but did not try to fit them, as I had got some spare 20" wheels from Duckworths. Only Range Rovers since 1988
Post #558356 20th Jun 2020 1:37pm
exalin
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Did you ever get a definitive answer on whether the style 15s fit on the SDV8 L405? 2017 Silicon Silver 4.4 SDV8 Autobiography
2009 Santorini Black 5.0 Supercharged V8 Autobiography
Post #609014 13th Oct 2021 11:36am
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
I know of no 19’s that will clear the front brakes of an SDV8.
Post #609177 14th Oct 2021 5:18pm
LT
As above.
I’d love to have 19’s but haven’t yet found any aftermarket rims that will fit.
Post #609198 14th Oct 2021 7:21pm
GraemeS
At least the L322 will accept D4 19" rims over its big brakes.
Post #609204 14th Oct 2021 7:54pm
LT
You can fit Range Rover 19" rims to the L405 models that have the smaller front brakes (V6 engines). Thumbs Up
Post #609269 15th Oct 2021 12:47pm
exalin
I was hoping the style 15s would be the exception as those fit over the larger 5.0 SC brakes on the L322 Sad 2017 Silicon Silver 4.4 SDV8 Autobiography
Post #610297 25th Oct 2021 7:36am
nbunney
Nope tried one of my style 15's and the off set is different.
I guess could fit spacers, but not for me.
I'm looking for a cheap set of 20's to put some AT's on now.
Post #611810 6th Nov 2021 2:02pm
cxdood
United States 2016 Range Rover HSE 3.0 SC V6 Santorini Black
My L405 has the 380 hp V6 petrol engine and came with the big brakes as well. 380mm in the front, same as the 500+ hp V8. I run 20" wheels on it.
V6s (diesel and petrol) with fewer horse power came with smaller brakes than that. I have seen the 340hp with 363mm fronts one year, and smaller in earlier years. L405 2016 - Supercharged V6 petrol 380hp
Post #611872 7th Nov 2021 5:49am
