Home > Maintenance & Mods (L322) > Rear Brake Mud/Dust Shields Corroded |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8230 |
They do pattern ones on eBay... a lot of the online spares places do them as well... you have to cut them in half and then weld or rivet them back together if you don't want to take the hub off unless someone has done a two piece one... needs lots of googling.. Pete
14th Oct 2021 10:53am |
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 189 |
Thanks Pete, just been Googling it and I see that I will need to cut in half and then rivet together as best option
14th Oct 2021 11:06am |
You have to make some tabs to rivet the two sides to each other, you also have to make sure the shoes don't rub against the rivets, so some planning with positioning is required... I'd use some polyurethane sealer as well just to help out... then paint all raw edges... I did it on my old fatty, it wasn't too bad a job... get a shoe fitting kit with new clips and springs as well... Pete
14th Oct 2021 12:32pm |
Oh, and remember, one side at a time for when you forget what goes where..!! Pete
14th Oct 2021 12:33pm |
Thanks Pete.
14th Oct 2021 3:21pm |
I'm just waiting for Duckworths to get back to me with a price for the shields, but good idea about getting the other bits at the same time. |
14th Oct 2021 3:23pm |
So I finally got round to fitting the new back plates. The old ones weren't actually that bad, but had rusted through enough for the brake pad pin to pull through.
7th Dec 2021 12:44pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
If anyone's doing this there is another way too rectify it. Order yourself a brake shoe fitting kit, preferably one that comes with the pin washer plates, angle grind the securing hole slightly wider so the brake pin fits through, place on the back of the brake dust guard, refit the shoes and push the pin through, jobs a goodun.
7th Dec 2021 1:05pm |
