Home > Maintenance & Mods (L405) > Climate control buttons
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
As a result of a sugary drink spillage, one of my rotary climate control knobs has become harder to rotate - so I expect some of the sticky drink has gummed it up.
Can these rotary controls be removed for cleaning? As part of a separate repair to fix the cupholder from the same incident I've recently removed the whole AC panel but this time I'm interested to see if the control buttons disassemble from the panel. As they are LED based I'm concerned not to just pull them off!
Thanks 2016 SDV8 AB
Post #608835 11th Oct 2021 10:53am
theres only one way to find out but be prepared to buy a new panel if its not possible..you could even upgrade to a newer touch panel . ... - .- -.
Post #608839 11th Oct 2021 11:36am
cass
Took a chance on this with my l322 that had a similar problem, gave it a liberal blast with electrical contact cleaner immediately followed with a blast of compressed air, It took 2 goes to make it perfect but I'm not sure I'd be brave enough to try it on a newer car!
Post #608848 11th Oct 2021 1:43pm
ABAB
Thanks both for the replies on this - very helpful.
I'm prepared that I might be in for the cost of a new panel so I would see the contact cleaner / air duster route as a good idea to try first.
I've not found any evidence yet of the rotary controls being removable. 2016 SDV8 AB
Post #608923 12th Oct 2021 11:08am
i removed my climate panel from my old L322 and its about 2cm thick and everything is integrated...
the 'new' touch screen ones are £599 so you can compare that cost to a new standard panel, if you need one that is.
link, https://www.ebay.co.uk/itm/373730755170 ... - .- -.
Post #608925 12th Oct 2021 11:56am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Careful Captain, The Op has an AB with (I assume) massage seats. These aftermarket screens do not support that - or a multitude of other functions it would seem looking at this:
https://www.rangerovers.net/threads/l405-a...de.348890/
Sorry Stan - slightly off piste I know. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #608948 12th Oct 2021 5:32pm
according to this thread you can get to the massage seat setting via the main screen menu,
If you have massage seats the button for massage seats on the digital AC unit is a dead button. It does not turn on or off the massage function. You also cannot toggle the massage programs from the digital AC unit. It’s literally a dead button on the screen that does nothing. So this means you have to go back into the OEM NAV screen and go into the seat settings and control it there.
https://www.fullfatrr.com/forum/topic60416-15.html ... - .- -.
Post #608963 12th Oct 2021 8:00pm
supershuttle
If sugary drinks can get behind it so can WD40, I use it all the time its safe and leaves no mess. Geoff
Post #608985 12th Oct 2021 11:28pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
I would be very carful what you spray on the rubberised control buttons they will turn a sticky mess, if it gets on the rubber parts.
Post #608995 13th Oct 2021 7:29am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
i have a 2016 climate panel. The hard to find model with the integrated heated cooling seats controls. Very good condition. PM me if interested. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #609020 13th Oct 2021 1:29pm
ABAB
Thanks for the offer Horse, but since we seem to be on different sides of the pond I’ll perhaps try a closer source if the repair means I need to replace.
Much appreciate the guidance from all over the world! 2016 SDV8 AB
Post #609045 13th Oct 2021 5:45pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I have a 2015 panel , I could possibly get it to Halifax if its any good to you. no charge , its from my 2015. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #609209 14th Oct 2021 9:19pm
ABAB
Dolph - that’s very kind of you. I’ll attempt the cleaning route first off, but if it doesn’t work I may well come back to you via a PM.
Cheers. 2016 SDV8 AB
Post #609240 15th Oct 2021 9:21am
